Cam install questions
Old Aug 14, 2014 | 12:46 PM
99yellowz28's Avatar
Default Cam install questions
I'm putting my cam in right now and I replaced the crank and cam gear and when I pulled the crank gear of I had to use a puller to break it free so when I put it on I used my old crank sprocket to press the new one on and the crank keyway is basically even with the gear I was just wondering if that was right.
