One 243, one 799
Old Aug 18, 2014 | 03:51 PM
jodyjo's Avatar
Default One 243, one 799
I'm looking to upgrade my 00 C5 heads in perpetration for a cam/stall. Found a guy willing to sell a complete set (one 243, one 799) for a decent price. I was under the impression that I won't have any problems. Correct?
Old Aug 18, 2014 | 04:25 PM
HCI2000SS's Avatar
Problems such as?
Old Aug 18, 2014 | 05:42 PM
01MAROONz2890's Avatar
if you're referring to the heads being the same then no. they are the exact same heads just cast at different places I have seen a couple vehicles have 1 799 and 1 243 from the factory
Old Aug 18, 2014 | 07:07 PM
jodyjo's Avatar
Problems in running one 799 head and and one 243 head... Any problems at all. I thought I had read on here where people have seen cars from the factory with this combo for whatever reason.
Old Aug 18, 2014 | 08:58 PM
redtan's Avatar
The only difference between those two heads is that one says "243" on the side while the other says "799". Last time I checked what markings are on the outside don't matter to the engine so you won't have any "problems" running two of the same head.
Old Aug 18, 2014 | 10:15 PM
jodyjo's Avatar
Thanks, I just wanted to check before I pulled the trigger.
Old Aug 19, 2014 | 03:29 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
The casting methods used for the 799 and 243 are different and produce different finishes. The chambers in the 243s will be smooth, and the 799s rough - this could have some minor implications with tuning for knock (you will always be tuning to the 799). I recently had a well known vendor try to sell me one of each (non-CNC'd chambers) and I told them to pound salt as that is just a shitty way to build a performance engine, and it would hurt resale options. I ended up with a matched pair of 799s from Texas Speed...
If it is a good deal, and you aren't particular like me, you'll be fine.
