compression issues
Hows it going guys so i have a 02 trans am with pretty much stock everything except the 243 heads and gutted the cats. Now heres whats going on i did a compression Test and it only reached 30 and if i leave it on for about a min it leaks down to zero iv tried on the other cyl and all stayed at 150 i dont have a leak down tester so any ideas to tell if its a valve or rings. Also when i drive and shift it back fires now any advice will be appreciated
Backfiring out of the exhaust or into the intake? If it were rings you would probably see more blowby than usual.
Although you don't have a leak down tester you might be able to use your compression tester if it's the screw in type to pressurize the cylinder if you can scrounge the fittings.
Put the cylinder in question at tdc of the compression stroke and pump some pressure into it and listen for leaks.
Put a couple squirts of oil in the bad cylinder and retest compression. If it build compression, whether it leaks down or not, that would generally indicate rings. If it still doesn't build compression, that generally indicates valves
