Add chain damper when swapping cam ?
Yes, it's worth it & be sure to check pump alignment parallel to the shaft when it's re-installed. I don't know if the CTS-V uses an LS2 or an LS3 chain, but if something other than an (LS2 or LS3 chain) add an LS2 or LS3 chain to the list.
