cam suggestions??
Old Aug 30, 2014 | 09:34 PM
uptonls1's Avatar
Default cam suggestions??
im doing heads and cam on my 99 z28. i have some prc stg 2.5 5.3 heads. they are milled to 59cc. my goal is low 11s on motor and 10s with a 100 shot. i know i cant run a huge cam with the small chambers but i want my goals to be met. dont really want to wait for a custom grind. any off the shelf cams that will get me closer to my goal? looking at vrx5 sns stg 2 and g5x3. any others i should look into? any help would be greatly appreciated. i dont want a cam that makes all its power up high but also dont want one that doesent make any power up high.
Old Aug 30, 2014 | 09:50 PM
HCI2000SS's Avatar
I think the MS3 cam is about as big as you can go here. I'm running a cam identical to that with the same heads and it works great!
Old Aug 30, 2014 | 09:54 PM
uptonls1's Avatar
what cc are your heads? stock bottom end? any flycutting?
Old Aug 31, 2014 | 09:48 AM
HCI2000SS's Avatar
Well I'm running a LQ9 now, so it's all different.
Plenty of guys running the PRC stage 2.5 5.3/MS3 combo without flycutting and it's a strong combo as well.
