LS6 valve length question
A while back I noticed that the valves, after installed in the head (I only replaced and installed two valves) were noticeably shorter from the tip of the valve to the retainer.
I removed the valves and discovered they are slightly shorter then my stock valves I pulled out of the same head.
I know ls6 valves were slightly longer then ls1 valves.
I also know that these new valves I bought weigh the same as my old ls6 valves.
Why the difference in length?
Can I get away with valve lash caps to suck up that .025" or should I go with different length pushrods just for two valves?
Or lastly, should I just shop around for more ls6 valves?
Also the ls6 valves were longer due to the smaller base circle of the ls6 can so it could compensate without longer pushrods
