LQ4 cam swap...now no spark!
Old Sep 4, 2014 | 12:19 PM
etcetc97's Avatar
Default LQ4 cam swap...now no spark!
I pulled the motor in my 2003 2500 truck to swap cam and valve springs. Everything back together and re-installed......but I cannot get any spark. I double checked connections on crank positioning sensor and replaced the cam positioning sensor. Tried to check DTCs while cranking and not seeing any codes. What else should I check????
Old Sep 4, 2014 | 10:20 PM
Mercier's Avatar
Have you checked the fuses /relays for the ignition? Did you make sure the ground to the engine is properly connected? Did you actually pull a plug and ground it to visually verify no spark? Did you change plugs at the same time?
