Lloyd Elliot 243 stage 1 flow numbers
Old Sep 6, 2014 | 12:27 PM
codyvette's Avatar
Default Lloyd Elliot 243 stage 1 flow numbers
I had a set of 243 LS1 heads ported by Lloyd and his customer service was great. His price was great so it left some speculation. I had them flowed next to a stock set of 243 heads I had on the shelf clean and ready to bolt on. For the money, I feel the results were better than I expected for sure.
PORTED IN EX STOCK IN EX
.200 156 118 144 97
.250 187 130 168 109
.300 216 148 194 125
.350 239 164 215 138
.400 251 177 229 153
.450 263 186 241 164
.500 275 196 250 175
.550 282 209 258 184
.600 287 216 Gains stopped
.650 293 219
Old Sep 6, 2014 | 01:20 PM
Kingc8r's Avatar
How much was his cost vs the other typical porting companies.
Old Sep 6, 2014 | 01:34 PM
JR 427's Avatar
Anyone have a comparison against any of the big name shops? What's your set up like OP? Do you have a goal ET in mind?
Thanks for the info
Old Sep 6, 2014 | 02:19 PM
American Psycho's Avatar
It seems like the price he charges for the stage 2&3 CNC work is pretty comparable to AI's prices. Right around the $1,000-1,100 range.
Old Sep 6, 2014 | 04:36 PM
JakeFusion's Avatar
Super Hulk Smash
What's the final port volume?
Old Sep 6, 2014 | 10:42 PM
codyvette's Avatar
I won't give prices for him but give hi a call. His prices are great, esp. in comparison.
Old Sep 6, 2014 | 10:47 PM
codyvette's Avatar
Thanks for the info
I am building a LS6 mock motor for a date night car. The only difference will be a compression bump and port work.... and maybe a little HP in waiting. LS6 cams take 243 heads to the edge of there flow limits so I am going to go as fast as I can with a stock cam, sound, and look.
Old Sep 6, 2014 | 10:50 PM
codyvette's Avatar
Double check that. I believe after all the stuff LE offers for no extra will well weigh out in his favor.
Old Sep 6, 2014 | 10:54 PM
codyvette's Avatar
I am not sure what they cc to but for the cost, I won't split hairs any further. I will post HP numbers when the build is done.
Old Sep 7, 2014 | 07:37 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Knowing the port volume isn't splitting hairs... it's kind of warranted depending on what someone is trying to do with the combo.
I'd be curious to know as well.
Old Sep 7, 2014 | 08:41 AM
codyvette's Avatar
I believe it is for such a small port job but it does make some difference. If I get a chance I will cc the runner and post it up.
Old Sep 7, 2014 | 09:15 AM
96capricemgr's Avatar
check several
Old Sep 7, 2014 | 07:33 PM
You could buy an aftermarket cam that performs much better than the LS6 cam, that also retains the stock characteristics that your after.
Old Sep 8, 2014 | 05:55 AM
Always2Slow's Avatar
Those are similar numbers I get out of a 243 head on stock valves. I really wouldn't worry about port volume so much and think its very bad way to judge a cylinder head. I like the fact that his port didn't stall at .600 which takes some work to achieve. Is there a better program out there sure there is, but for the price he paid I bet he got a pretty good deal.
Old Sep 8, 2014 | 07:32 AM
redtan's Avatar
Here is a comparison of the LE1 heads vs. the basic portings of TEA and AI (both with stock valves). Depending on the price of Lloyd's heads (both of these are right around $1000) those seem to keep up under .400 lift very well for hand ported heads.
Old Sep 8, 2014 | 09:37 AM
codyvette's Avatar
I have had several small cam setups. Even down to a 216/220. They don't quite sound stock. When it is time to perform, this combo will have the added help I want. I have other cars for big cams and peak performance. The LS6 cam almosf free.
Old Sep 8, 2014 | 01:40 PM
Again your basing internet numbers against verified numbers a very bad way to compare heads. Your not also counting that LE1 heads were flowed farther and still picked up see what that looks like on a graph as well and I wonder why TEA doesn't have flow numbers past .600. AI has numbers to .700 but its on their own bench and not the one he flowed his heads on. What if his bench is calibrated and ended up reading 8 cfm lower? LE1 heads would look a whole lot better now wouldn't they. What if the port volume was closer to 226cc? If you compared that port with this one bench variance could easily account for the difference. TEA I believe doesn't use a superflow bench, which isn't a bad thing it's just harder to compare numbers. What if other characteristics of a cylinder head made more power than just raw flow? How would you then compare these heads?
Old Sep 8, 2014 | 02:49 PM
codyvette's Avatar
My head work was quite a bit less than $1000 and included new .660" Lunati spring kit. For the application the work I had done will make great power. The other companies I spoke with wanted way more money. That would be fine if I didn't already have my own castings and valves. In my particular situation it was a no brainer.
Old Sep 8, 2014 | 04:44 PM
redtan's Avatar
Unless the OP actually sat there and calibrated then ran the machine, the numbers provided by the vendor (in this case Llyod Elliot) are just as "verified" as any other number you find on the internet.
As many people have verified, flow numbers past .600 on the heads are almost meaningless unless you have a single plane intake. With a composite intake, even a ported FAST, all the power is made under .600 lift. So in fact, when someone praises that their heads flow 320 it means crap. The lower lift area is where you make power.
Look I'm not bashing LE or saying other heads are better, someone simply asked for a comparison and what I gave is about as accurate as you can do. Unless some has ran the LE heads and others in the same exact engine setup, there's not much else to do an apples to apples comparison.
Old Sep 9, 2014 | 09:29 AM
codyvette's Avatar
Both of you make valid points. I simply posted a quick thread with somewhat comparable numbers do to the fact I had a stock and cheap port job compared at the same time under the same condition. For a build like this with a stock LS6 cam, LS6 intake, etc. I feel like this was definitely the way to go with the heads. Folks will need to look at each build for what it is. All of theses companies make different stage heads for different money.
