No spark after cam swap
Old Sep 6, 2014 | 03:49 PM
etcetc97's Avatar
Default No spark after cam swap
Hello all, I am out of ideas and looking for help!
I pulled the 6.0 out of my 2003 truck to swap cams/valve springs. Re-installed engine and cannot get any spark. So far I have changed Cam Positioning Sensor, Crank Positioning Sensor, double checked all connections and ground wires....no luck. I hooked up my tuner and have no DTCs showing up.
Any ideas??
Old Sep 6, 2014 | 04:26 PM
svede1212's Avatar
Checked fuses?
Old Sep 6, 2014 | 04:27 PM
george88gta's Avatar
Missing/damaged ground wires at the back of the heads?
Old Sep 8, 2014 | 06:04 AM
gagliano7's Avatar
Since you pulled the motor out sounds like a wiring problem somewhere when you put everything back. Make sure you check all your grounds and double check all you wiring.
