oil in the TB?
Old May 23, 2004 | 02:07 PM
longdaddy's Avatar
Default oil in the TB?
I have noticed that after I run the car for a while and then shut it off, there is a little bit of oil collecting at the bottom of my TB blade- is this normal?
I have replaced PCV valve but the oil is still there...
I am trying to troubleshoot partial throttle ping, more info is here:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/173687-still-pinging-thinking-about-buying-rice-burner.html
Old May 23, 2004 | 02:19 PM
plumbr's Avatar
Its the poor pcv system design GM gave us. do a search on catch cans, it has solved my similar problem.
Old May 23, 2004 | 08:29 PM
AZ Power & Sound's Avatar
convert to the LS6 PCV... ive done over 20 conversions and 90% solved the problem by doing this... the parts are under 100 bucks and it takes about 2 hours to do...
Old May 23, 2004 | 10:30 PM
1BADFNZ's Avatar
Install a AMW catch can---------------->
