Does a new GM LS1 block need machining?
Old Sep 14, 2014 | 01:19 PM
kristov's Avatar
Default Does a new GM LS1 block need machining?
http://www.summitracing.com/int/part...1166/overview/
When buying a block like this - does it need any kind of machining (decking, boring etc.) or can you just start assembling it with new parts?
It will be used to rebuild a stock LS1 with a bad block.
Old Sep 14, 2014 | 01:40 PM
Fat Jesus 808's Avatar
Yes, they are shipped at 3.890" bore. Ls1 bore is 3.898"
Old Sep 14, 2014 | 02:04 PM
kristov's Avatar
Thanks!
What about decking the HG-surface?
Old Sep 14, 2014 | 03:33 PM
That should be machined alredy, but might as well have it checked and make sure its flat
Old Sep 14, 2014 | 04:06 PM
00SlvrSS's Avatar
I advise anyone that buys a block "fresh" gets it machined totally and build according. There's nothing like knowing your clearances and decking for a little more quench and know you have a straight line hone done.
Old Sep 14, 2014 | 06:17 PM
Fry_'s Avatar
Would be better off with a LS2 block only $229 more and already has freeze plugs and cam bearings installed
Old Sep 14, 2014 | 06:36 PM
Pbeyer2010's Avatar
$1000 seems like a lot for a block that has to get machined anyway. IMO i would look for a good used LS1 block for a few hundred bucks and have that machined... my $0.02
Old Sep 14, 2014 | 06:56 PM
Paul Bell's Avatar
That's MISTER MODERATOR
^THAT.
And, any engine block should spend some time at a machine shop getting everything miked as well as getting the camshaft, pistons & rings fitted.
You can do the final assembly yourself.
Old Sep 14, 2014 | 07:08 PM
redtan's Avatar
Yeah if you're going to do all that work you might as well save some money and get a used block. The whole point of buying new is not to have to all that work. A used block after proper machining is going to be just as good as new given that it's in good condition.
Old Sep 18, 2014 | 02:38 PM
Pbeyer2010's Avatar
If your interested, i am selling an ls1 block for $350, buyer pays shipping and fees from 10984. Search the classifieds for my post.
-Phil
