Help me figure out Compression ratio
Old Sep 16, 2014 | 09:08 PM
yoshgixxer's Avatar
Default Help me figure out Compression ratio
http://www.csgnetwork.com/compcalc.html
Used this calc above and it seems to be very high. Or maybe im a retard. Some one else run these numbers on another trusty calculator and tell me what u come up with pleaseee!
4.030 bore
4.0 stroke
.051 gasket/ 4.085 gasket bore
.006 Deck
-28cc dish turbo pistons
65cc chamber
cam specs.. 234/239 .612/.610 115+5
Old Sep 16, 2014 | 09:18 PM
KCS's Avatar
KCS
Moderator
I got 9.3:1.
Old Sep 16, 2014 | 10:22 PM
yoshgixxer's Avatar
That sounds better! What calculator did u use?
Old Sep 16, 2014 | 10:50 PM
LLLosingit's Avatar
I got 8.947206773152123:1 using the calculator you linked.
Old Sep 16, 2014 | 10:55 PM
LLLosingit's Avatar
are you sure you put your piston in as a -28
Old Sep 17, 2014 | 08:42 AM
yoshgixxer's Avatar
Yea i put the - in . Clearly enterd somthing wrong lol
