LS2 safe cam lift
Old Sep 22, 2014 | 08:02 PM
mika401's Avatar
Default LS2 safe cam lift
Years ago I had a set of 243 heads sent to TS/PRC for their stage 2.5 work with .650" springs and also milled .02. Originally they were going on a LS1 block but plans have changed and now I want to bolt them onto a stock bottom end LS2 block. Question is what would the safe amount lift cam I can run without running into PTV issues.
Old Sep 22, 2014 | 08:04 PM
redtan's Avatar
You can run upwards of .63x and be ok, but it's kinda pointless as the intake and heads probably run out of breath by then.
Old Sep 22, 2014 | 08:42 PM
mika401's Avatar
That was kind of my next question right now I have on the shelf a 224/230 610 605 113+4 cam that I can drop in together with an LS6 intake. If its safe to run with no PTV issues would I leaving a lot on the table by using this cam.
Old Sep 22, 2014 | 08:43 PM
redtan's Avatar
You'll be more than ok with that.
Old Sep 22, 2014 | 09:24 PM
KCS's Avatar
KCS
Moderator
Think for a minute, where are the pistons when the cam is at max lift?
PTV is more about the overlap area than it is about max lift.
Old Sep 23, 2014 | 06:19 AM
mika401's Avatar
Yeah got a little nervous when I called TS and they told me max to run with this combo would be .580 lift, was like WTF!
Old Sep 23, 2014 | 07:24 AM
MuhThugga's Avatar
Yep. Gross lift doesn't really affect PTV issues. Ramp rates and overlap do.
OP, if you have that camshaft on hand, the best thing to do is install it and measure. It takes extra time, but at least you'll know for certain.
Old Sep 23, 2014 | 10:54 AM
farmington's Avatar
it beats buying one and then measuring and finding it won't fit
