No oil pressure?
Old Sep 24, 2014 | 05:25 PM
airattack111's Avatar
Default No oil pressure?
I recently changed the seal on my map sensor as well as the upper intake gaskets to fix a vacuum leak.
Started the car up and it runs like a charm. But the oil pressure gauge reads 0... when I turn the car off the gauge rises slightly for some reason.
I took the intake off but don't remember messing with the oil pressure sensor. I felt behind the intake manifold after reinstalling and felt the sensor, it feels like something should be plugged in but in the picture you can see a wire going to it. Am I missing something?
oil pressure
Old Sep 24, 2014 | 06:01 PM
the sensor kind of wobbles when i put my hand back there. Kind of confused. It has to be getting oil pressure it runs like a charm. Just kind of scary. Is the sensor supposed to wobble around?
Old Sep 24, 2014 | 06:13 PM
Ok the sensor is broken... LOL
All it does is read oil pressure right? Doesn't mess with PCM settings? If that's the case I'm just going to order a new one and drive it in the meantime.
Old Sep 24, 2014 | 08:10 PM
conan's Avatar
It only reads oil pressure. I personally would leave the intake out and fix it before driving, I watch my oil pressure gauge like a hawk. Any local auto parts should stock it or be able to get you one same day.
