found metal in the intake (pic)
The symptom was knocking sound from the intake.
The car is C5 Ls1 H/C.
As far as it being anything related to the pistons, I've only ever saw that in major blow ups when valves contact pistons and starts eating itself.
I would look at everything leading into the intake itself.
How was the car running other than the sound coming from the intake?
It was probably flat and got curled up. Pull the heads and you see the damage in the combustion chamber.
BTW don't reuse that intake on the next engine. There are probably more smaller pieces that have not come out.
Or buy one: http://www.harborfreight.com/High-Re...der-60695.html
Number 7 runs lean and hot.
we see it all the time....
find pieces in the other side of the engine from where the broken piston is
anytime something comes loose inside a cylinder, it can come up and bounce around the intake...
air doesnt just go in the intake and out the exhaust....
it mostly does, but it breathes both ways at the cam overlap.
piston parts often end up in the intake and then crossing to somewhere else causing more damage
hell... I've even seen half a valve end up in another cylinder....
and it allows air and steam to escape that gets trapped back there.
theres a reason they keep that rear vent on the nascar LS engines
and I can tell you as an engine builder, I see less problems with #7 and #8 on the engines that have the rear vent/crossover setup
