Texas Giant or Polluter to replace MS3 in 370
Well, I finally pulled my old 346 apart and my MS3 is SCREWED... Got gouged by a piece of the rod that broke, so time for a new cam. I figured I should go ahead and get somethng a little "better" to take advantage of the few extra cubes, as well as a few intake goodies. I don't have AC, so I think I'm going to go with the Chris1313 ram air and ditch the SLP flopac cai, and swap my 85mm SLP maf for a TSP 100mm unit. Think either/both of those will net me anything? Also going with an ATI 25% underdrive pulley without the AC pulley on it, figure that's good for a few ponies.
For cams, I'm looking at the polluter v1 (242/244 | .61x”/.61x” | LSA112) and the Texas Giant (248/254, .615"/.622", not sure which LSA to go with)
I don't really know what lobes either of those cams use.
Which do y'all think would show me more power/be faster in a 370 w/ -2cc Diamond flat tops, afr 205's (already have YT ultralights, will be reshimming) and FAST 92/PTM92? I have a Yank 4000ss and 4.10 gears.
I'm not very knowledgeable on cam selection. I don't want it to be a complete dog, but my understanding is that the converter will keep me out of the low-range for the most part. I like to run on the street and will be driving it fairly regularly, but manners aren't all THAT important. I DD'd my MS3 for two years, loved it. I just want to put a hurtin' on some people, on the street as well as the track. when I go.
What do you think? Would the texas giant be too big, or would it make for a nasty combo?
This is what I found:
http://www.engpwrsys.com/index.php?a...d&productId=11
Just an update- I ordered the EPS 236/248 mentioned above. Geoff had nothing but good things to say about it.
Now I just need to find a degree wheel (don't know if anyone rents them) and pick a timing set.
The reality is when someone sells you a camshaft they haven't tested side by side with any other camshafts they simply don't know what does & doesn't make more power.
You really need to decide how much power you want to gain to make it worth the cost in upgrading. If your ok with 8-10hp then I think if you do something smaller than the Tx Giant you'll be happy. Maybe something like a 243/247. The problem with the Tx Giant is its way to big for this application I think. You might make some extra peak hp, but I think you'll find overall you didn't make any ground.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
The 236/248 EPS cam will perform a little different from the MS3. The later exhaust duration will allow it to hold on past peak better, plus it has more overlap so it will make more power. Also, it has an earlier IVC, so it should make more avg torque. Overall tho, I don't think it'd be a huge difference - maybe 5-10HP.
final specs are in on the cam, I guess the EPS site is wrong on the lobes. talked to Geoff
cam specs are: 236/248, 110+3 (107 ICL ), .604"/.604".
the only reason I switched from my ms3 was because the broken rod smacked the **** out of it and it was done. since all cams are close in price, I decided to get something better suited to my build, and the EPS cam should fit the bill nicely. the lobes should be a lot kinder on my valvetrain, and offer a lot more valve control with my heavy-*** YT Ultralites. it might not make that much more peak, but I should wind up with a lot more under the curve right where I want it, and it should from my understanding perform a LOT better.
I plan on degreeing it in at spec. any thoughts?
