Verify a sound for me.... Video inside
This all started when the motor ate a piston a month or so ago. I found a new junkyard motor and swapped it in. After the new motor went in it made a ticking noise from the flexplate area. Upon inspection, i noticed a ton of thrust play. Pulled the motor back out, replaced the main bearings and crank, and then re-installed everything. This brings us to yesterday. Started the car up, drove a block, and now i have the same noise.
Thrust movement is no longer there. I am to believe its a warped/cracked flexplate. Last night i pulled the transmission. Everything seems to visually check out ok. The only thing that i can think of is a warped flexpalte. I have no good way of checking the center of it to see if its warped or off kilter a bit. What does this noise sound like to you? You can visually see the flexplate wobbleing in the video.
