Couple Questions On My Ls1
Finally started putting my 2000 camaro ss back 2gether these are all the mods Im doing
-TSP 224/224 .581/.581 114lsa
-Stock 243 heads
-PRC .650 Spring Kit.
-7.4 TSP Hardened Pushrods.
-Ls7 Lifters.
Ls2 Lifter Trays.
-Ls2 Time Chain.
-Ls6 oil pump.
-Ls6 Intake Manifold.
-Long Tube Headers (speed engineering)
-Ac Delco Knock Sensors.
-TSP Underdrive Pulleydumdum25%.
-B&M 3k Stall
-Slp Lip & K&N Filter
-self port and polished tb
-Transmissions shift kit (TransGo)
-New Clevite Rod bearings stock size
Do I need to brake in the new cam??
Do I just put in the new dual valve springs in 2gether in the heads or do I put the outer one first heat cycle then add the inside spring and go through another heat cycle???
Anybody got any ideas wat hp numbers I should be seeing with a tune???
Any tips or suggestions more then welcomed
-Stock 243 heads
-Ls7 Lifters.
Ls2 Lifter Trays.
-Ls2 Time Chain.
-Ls6 oil pump.
-B&M 3k Stall
