tea 243
Old Oct 26, 2014 | 07:29 AM
sbf's Avatar
sbf
Default tea 243
i have a set of tea stg2 243 and need to no if i need them opened up for ls3 block.i talked to the guys at tea they say no but all the tfs 215 had to be opened for the larger bore i need to no before i get my short block.any ideas
Old Oct 26, 2014 | 08:12 AM
A.R. Shale Targa's Avatar
You do not have to but if you're dead set on it, any decent cylinder head guy can gasket match the chambers......assuming that's what you mean.
Old Oct 26, 2014 | 09:40 AM
KCS's Avatar
KCS
Moderator
You don't need to but it wouldn't hurt to open up the chambers and deshroud the valves.
Old Oct 26, 2014 | 07:29 PM
sbf's Avatar
sbf
That's what I was saying
Old Oct 26, 2014 | 07:30 PM
sbf's Avatar
sbf
I don't no about the gasket match but I read where guys saying they opened up the chambers for bigger bore
Old Oct 26, 2014 | 08:52 PM
KCS's Avatar
KCS
Moderator
You could put the dowels in the head and use your headgasket as a template for the bore size.
Old Oct 26, 2014 | 09:41 PM
JakeFusion's Avatar
Super Hulk Smash
You can send them back to TEA. They have a 2.08 and 2.10" intake valve program based off the 235 and 245 valves in the TFS heads that they can apply to the 243s. They can also take the head out to a 4.1" bore or whatever. It's basically the "stage 3" treatment.
The 226cc port will become like a 229 or so with the blending of the port to the new valve job. So that's pretty good for a 416. You'll pick up like 8-10cfm as well. Just going to the 4.065" bore will raise your flow numbers about 8-10 anyway. So this is in addition.
Old Oct 27, 2014 | 08:33 PM
redtan's Avatar
How much improvement in terms of flow and/or power can be gained from going to a 2.08/2.10 valve over a stock one?
Old Oct 28, 2014 | 12:09 PM
sbf's Avatar
sbf
Originally Posted by JakeFusion
You can send them back to TEA. They have a 2.08 and 2.10" intake valve program based off the 235 and 245 valves in the TFS heads that they can appl235y to the 243s. They can also take the head out to a 4.1" bore or whatever. It's basically the "stage 3" treatment.
The 226cc port will become lgonna aprike a 229 or so with the blending of the port to the new valvewww ant job. So that's pretty good for a 416. You'll pick up like 8-10cfm as well. Just going to the 4.065" bore will raise your flow numbers about 8-10 anyway. So this is in addition.
I talked to them about two weeks ago about the stage 3.to me its not worth it because ill have to spend $1800 to do it i can sell mines and put money with it and get the tfs 235 or 245.Im just trying to see if the chamber needs to be opened for the bigger bore.also i asked about the ls3 turned down valves i said i was gonna spray nos they said not a good idea to go with the valves.I just want some for sure answers.I wish mike still worked there
Old Oct 28, 2014 | 12:20 PM
JakeFusion's Avatar
Super Hulk Smash
1800? wtf
Old Oct 28, 2014 | 01:15 PM
sbf's Avatar
sbf
1800? wtf
I have stage 2 and for stage 3 my heads has to be torn down re cnc and hand ported and new valves, springs, etc.from a fresh start he said around 3200.I guess if someone has to run a certain class or try to trick in street racing it would be good but not for me ill stick with what i have i think mines will do good on a 418 with super vic and scorpion 4150tb
Old Oct 28, 2014 | 01:19 PM
sbf's Avatar
sbf
Hey jake fusion I been following your build have u got any dyno numbers yet.I was gonna do a sbe ls3 with my heads fast 92 and the same cam u have but I got a heavier car now so im gonna go stroker
