403 ls2 oil pressure issue
Old Oct 26, 2014 | 08:09 AM
dodson55's Avatar
Default 403 ls2 oil pressure issue
I am wanting to get some thoughts and opinions about oil pressure on a ls2 403, motor has 50 miles on it as of right now and at 1000 rpm idle I am getting 20-25psi hot idle 40-45 cold idle, I am using 10w30 mobil oil, king rod and main bearings the clearances are .0024-.0025 on mains and .0022-.0024 on rods I am using a ported and shimmed ls6 oil pump, am I being over paranoid or is that to low, the lq4 I removed held 40 hot idle with stock ls6 pump and same oil, should I just not worry about it and run it as is, try thicker oil, try a different oil pump, or should I try to tighten the main clearance up some since I have been worried it is to loose since im running an aluminum block
Old Oct 26, 2014 | 09:21 AM
activegee's Avatar
Default same problem
I wanna know the answer to this also, I have a 370ci 6.0 about 700miles on it with a base tune, the shop told me it have a melling pump (not sure of the part #) and its a 40psi cold and 22-25 hot. w.o.t it stay at about 25psi and once I get out of it it jumps to 30 and come down to 22 again
Old Oct 26, 2014 | 03:51 PM
Jimbo1367's Avatar
While those numbers aren't horrible and you both have fresh motors, I'd double check that the pick up tube o-ring wasn't pinched.
Old Oct 26, 2014 | 04:31 PM
dodson55's Avatar
I have double checked that, I feel that mine is in the main bearing clearance I drove it more today it will hold 35-40 at a hot idle if I let it idle and warm up but after driving it about 30 min it will hold 20-25 at idle im thinking about trying to install a .001 bearing on the lower of the mains to tighten my clearance up to about .0019 to see if that wont help
Old Oct 26, 2014 | 05:45 PM
Gray86hatch's Avatar
I would not run the mains that loose.
Rods are fine
Tim
Old Oct 26, 2014 | 10:17 PM
dodson55's Avatar
i thought it was to loose to but i talked to a few places and my machine shop and they said it would be fine but i think they mush have got confused and must have thought i had a iron block, i think ill change bearings on the mains and see what happens, question is should i put a full set of .001 bearing in it to se the clearance at 1.4 ish or use half a set and set it at 1.9 ish
Old Oct 27, 2014 | 06:37 AM
Shoot for .002
Old Oct 27, 2014 | 09:30 AM
dodson55's Avatar
I can find a set of king .001 bearings does anyone know if standard clevite bearings run tighter the then kings I have read that they do but would like to know from someone that has personally tried both
Old Oct 27, 2014 | 11:22 AM
KCS's Avatar
KCS
Moderator
I'd be okay with that oil pressure as long as it didn't get lower with RPM, but I would like to see more if it were my car. A Melling 10296 or AFM style pump would bring pressure up at idle and above, and be a lot easier/safer than swapping out the bearings.
Old Mar 2, 2015 | 11:19 AM
activegee's Avatar
Default found my problem
bearing clearance was off so I started losing super pressure close to nine after running the car past 20mins.
Rebuild with a procharger lol
