Normal valve spring pressure loss.
Old Oct 26, 2014 | 12:21 PM
dtroike's Avatar
Default Normal valve spring pressure loss.
I am using a set of K-motion K800 valve springs and after checking them they have lost about 20-30 lbs at 1.79” and at 1.13”. When I checked them new they were 495-500 and 195-200. Now they are 470-475 and 170-175. I am in the process of switching to a cam with slightly less aggressive lobes and they pressures they are at now are about what im looking for. Since they have already lost some pressure will they level off or will they get worse faster? What is a normal amount of pressure to loose on a spring that is still good? Are these good springs? Right now they probably have about 600 semi hard street miles on them, maybe 60 1/8 mile passes, and they are 3 years old.
Thanks
Old Oct 26, 2014 | 10:11 PM
S10xGN's Avatar
Hmmm, I've got Comp 941 springs in my turbo truck. Put them in around 2002, pulled & checked them in 2011 during a rebuild and there was zero loss. I'm sure someone (or a vendor) will chime in...
