ms3 or ms4
Old Oct 26, 2014 | 06:57 AM
nazztman4739's Avatar
Default ms3 or ms4
I have a completely stock 2000 z28 (ss clone) I'm looking to change the cam and possible heads question is will I need to fly cut my pistons I'm going with ms3 or 4 either stock heads or ls6 stage 2.5 I know I will need change springs and possible lifters what about pushrods remember this is completely stock I have done all out rebuildsbut never just can swap
Old Oct 26, 2014 | 07:23 AM
madmike9396's Avatar
you can find a better cam in my opinion.
a cam that big isn't going to shine well being all clogged up by stock intake and manifolds
Old Oct 26, 2014 | 07:26 AM
Yeah I understand that I'm in the works finding a ls6 intake and probably some cheap eBay headers I just want to make sure I don't have to flycut
Old Oct 26, 2014 | 07:46 AM
What makes you want a ms3 or ms4 ?
Old Oct 26, 2014 | 07:48 AM
JIMS SVT's Avatar
I had a ms3 in my frc when I bought it. Ls6 intake,stock heads with prc springs,stock maniolds,stock cats,x pipe and catback and it made like 346rwhp with someones tune. Did a set of obx longtubes,made a 3'' x pipe and speed density tune with no maf in place. Cincyspeed tuned and it made 408rwhp.
Old Oct 26, 2014 | 08:29 AM
HCI2000SS's Avatar
If you are "completely" stock then you shouldn't even consider a cam change yet. At minimum you need some exhaust work. Even then you still have stock gears which will suck with those cams. You might wanna do a little more research first
Old Oct 26, 2014 | 09:37 AM
Can change for loapy sound I have had nice cammed cars had a 383 with ms4 car does have 373 rear in it and eventually I am doing other work to it I just need to know if either of those require fly cutting
Old Oct 26, 2014 | 09:45 AM
My final goal will be ls6 or fast intake ported ls6 heads cam I have exhaust coming loudmouth 1 am def getting headers and ory in near future my final goal is only 400-450 HP but like the aggressive lope
Old Oct 26, 2014 | 09:52 AM
Cstone812's Avatar
I dunno why everyone flocks to these cams I still see these posts on here and facebook groups. Get a custom cam specd out or a btr cam or tick cam these are old school cams that will still work but there are better options available now. These two cams are max effort cams meaning you need the best **** to work a ls6 intake and ebay headers will choke the life out of it you need a fast intake and 1 7/8th headers a good converter and some gears. I wouldn't even waste my time with them if you are a six speed . Oh and the ms4 cam is complete garbage imo if you are dead set on one of these then go with the ms3 but don't get mad when you get beat by guys with smaller cams that are setup better. And no you won't need flycutting with either cam unless you have your heads milled.
Old Oct 26, 2014 | 10:35 AM
2kgtp's Avatar
I have a ms4 in my ws6 with untouched 243 heads, bbk long tubes and stock ls1 intake for now, the car feels amazing. And idle sounds great to! I didnt fly cit my pistons
Old Oct 26, 2014 | 10:38 AM
Cstone812's Avatar
BBK longtubes and a ls1 intake....Lololol sounds like a great setup.
Old Oct 26, 2014 | 10:45 AM
Try 2k this post getting way off topic I honestly just need to know if I will have to flycut with my heads
Old Oct 26, 2014 | 11:07 AM
HCI2000SS's Avatar
The MS3 should clear stock heads and certain others, and the MS4 usually won't clear stock heads and may or may not with certain otheres. It depends on what heads are chosen, how much they've been milled, what gaskets are used, etc....
Old Oct 26, 2014 | 11:29 AM
Probably ls6 2.5 62 or 64 cc chambers std mls style gasket
Old Oct 26, 2014 | 11:31 AM
2kgtp's Avatar
I dont see any problems with it. Everyones a critic i guess lol
Old Oct 26, 2014 | 12:08 PM
Lol yeah its cool everyone has valid points it just wasn't the question at hand.
Old Oct 26, 2014 | 04:13 PM
any cam can sound lopey with a low LSA
Old Oct 26, 2014 | 05:20 PM
kinglt-1's Avatar
yes you will probably have to fly cut with a ms3 and milled heads to get the compression up where you need it.
Old Oct 26, 2014 | 07:58 PM
2kgtp's Avatar
https://ls1tech.com/forums/generatio...-t-matter.html
Old Oct 26, 2014 | 08:51 PM
Rise of the Phoenix's Avatar
Overlap is what makes a cam lope.
