Opinion on Cam
Old Oct 28, 2014 | 05:45 PM
sssdavesss's Avatar
Default Opinion on Cam
I am looking for an opinion on a cam I have in my car. This is what it says on the box. Dur@050
Dur@050 Int 231 Exh 240
Lift Int. 611 Exh.601
Not gonna lie dont know much about cams.
I have a set of stage 2 862 Heads. 390 gear. Full exhaust and a few other bolts ons.
My goal is to put a Procharger on over the winter and be around 600-650hp. I am looking for any thoughts and opinions on if the cam should be changed. Also, clutch, 12-bolt in the near future. Along with a new bottom end when it breaks. I want to keep it street friendly. As of now I dynoed 425 hp at the wheels. Is this decent with my current setup?
Thanks for your help in advance!
Old Oct 28, 2014 | 06:09 PM
HCI2000SS's Avatar
5.3 heads right? Who did the work on them? I have those same heads as well. What's the LSA on the cam?
Old Oct 28, 2014 | 06:13 PM
sssdavesss's Avatar
CLS 285/295-13HR Not sure if thats what your asking but the only other numbers on the cam box. Seem to be right?
Old Oct 28, 2014 | 06:15 PM
99Bluz28's Avatar
What's the LSA on the cam, how do you like it, is it street friendly enough for you..?
Yes, though are decent rwhp numbers.
Old Oct 28, 2014 | 06:22 PM
HCI2000SS's Avatar
No its probably like a 112 or something along those lines. Should be there
Old Oct 28, 2014 | 06:25 PM
99Bluz28's Avatar
Who made the cam(it should be on the box)..?
Old Oct 28, 2014 | 06:28 PM
sssdavesss's Avatar
Heres the box for the cam. I dont know much about cams at all. Would this give the requested info?
Old Oct 28, 2014 | 06:35 PM
sssdavesss's Avatar
Found this card looks like 113?
Old Oct 28, 2014 | 06:47 PM
HCI2000SS's Avatar
Yep 113 LSA with 4 degrees advance. Not a blower cam by any means but it should do okay with mild boost
Old Oct 28, 2014 | 06:51 PM
STAR's Avatar
If you like the way the cam performs, sounds, drives etc. I would keep it. It will work fine with the blower and you should be able to hit your goal. Spend the money on the drive train
Old Oct 28, 2014 | 07:09 PM
99Bluz28's Avatar
Another plus is that the cam lobes are fairly mild which is a good thing with F.I.. The intake lobes having a 54* ramp rates, and the exhaust lobes having a 55* ramp rate. it also has a decent I/E duration split The only down side I see is it having 9.5* overlap, which is a lot more than I would want in a blower cam, especially in a LS1 engine. Ideally I'd run a least a 14* I/E split, and no more than about 4* overlap preferably less. I'd say run the cam and unless you find that it's bleeding off boost stick with it.
Old Oct 29, 2014 | 12:51 PM
rpturbo's Avatar
I agree with 99Bluz28. Are there better cams, sure. I think you'll be impressed with how it runs though. In the past, I built many ProCharged cars, and ran all kinds of "incorrect" cams, only to smoke the guys saying "that won't work".
