Suggestions/recommendations about valvetrain upgrades
I'm really just double checking to see what works, I don't wanna tear apart the motor once it goes into the car, especially after seeing a guy in my auto tech class drop close to $2500 on his SBC top end only to have a joke of a power band and power output on the dyno because he just went and bought the best brand name parts he could and didn't do the math/research to see what works together and what doesn't.
I know it's a lot to read but any input is much appreciated
Also, if your willing to give up some low RPM manners, instead of the 224/224 go bigger. Maybe the Comp Cams HUC 231 lobe (catalog # 13045) single pattern 231/231 HUC.598/HUC.598 should be stable and breath very well at 7K but on a LM7 will not be as nice to daily drive as the 224/224. Maybe a cam from Cam Motion or EPS.
Read https://ls1tech.com/forums/generatio...alvetrain.html
goin with ARP connecting rods & a SLP ported oil pump. Also gonna try and get a 98-02 F-body oil-pan w/ windage tray. I shall look into that crank scraper and CC HUC though, thank you I'd either have the cam done on a custom grind with 0 advance or get a adjustable timing chain/gear set and retard the cam however much its advanced in the grind(typically 3*-4*) .
My dad's car has a cam and spring kit from him has 18000 miles on it with nothing other than oil changes.
Tim
So the XE-R lobe sounds like a better cam but there are trade-offs. Because it opens the valve so fast it's hard on valve springs and lifters. They will wear out much faster. Also, your pushrods will try to bend because of the fast ramp rate. As you rev to your 7000 rpm goal, your pushrods could act like springs and loft the valve off the nose of the cam, valve float. This is the point that the soft XE lobe catches up. It may have another 300 to 400 rpm before the float begins and that extra rpm is extra horsepower.
Here's a link to the kit I want to get for any reference: http://www.hawksthirdgenparts.com/cam-kit-hawks-ls1-ls6-stage-3-camshaft-package/
Here's a link to the kit I want to get for any reference: http://www.hawksthirdgenparts.com/ca...shaft-package/
The kit you linked to seems fair but I think you have more reading to do to make the best choice.
This will help.
Also, I'd stay away from Hawks. WS6Store offers better pricing.
But in all honesty, I ended up buying all the components of my valvetrain from about 8 different vendors. Why? Well, that's the only way I got exactly what I wanted.
