Need advice for ls1 h/c/i
Built transmission from a Good shop
Yank 4000 stall PT series
Transmission cooler
Bigger transmission pan
Strange s60 with 390 gear
lower control arms- you already got
pan hard bar- you already got
adjustable torque arm
Find some 243s or 799s Have them sent to a Good shop for porting and Valve job
All new gaskets
A nice cam kit with all accessories Springs locks retainers etc
Push rods
New lifters
New oil pump
ls6 timing chain
Fast 90 or 102 intake and throttle body
Are you doing the work your self or having a shop install everything ?
Transmission cooler
All new gaskets
Push rods
New lifters
New oil pump
ls6 timing chain
OP....Shoot me a PM and we can discuss the goals of your build.
I can design a combination around stock AFR heads or modified AFR heads (aka Mamofied) with stock solid stem valves or aftermarket hollow valves which I recommend if you plan to make big power which always requires a decent amount of RPM with stock cubes (stroker motors dont require as much RPM because they inherently make more torque).
Sounds like you have some budget to work with.....if so a properly ported FAST is a no brainer....if you have really good heads it can be worth 25-30 RWHP.....thats just too large a chunk to leave under the table if your trying to punch a number.
Cruise thru the gallery on my new website to see the workmanship and the quality of the Mamofied heads if your considering that....there should be some pics of a few FAST intakes I ported in there as well
www.mamomotorsports.com
I can help you get where your looking to be and do so in a reliable and very drivable combination....and that's the real difference....a combination that can lay waste to most but yet still be civil enough to drive your GF or wife to the movies....still have the manners of a "normal" car. Responsive....no surging or protesting at low RPM's, and none of the typical pitfalls of larger less efficient combinations
-Tony
-Tony
His options are great for that kind of budget though if he does spend all 5k im guessing he should make around 450+. What do you think? Does that sound about right?
Nice man id say from everything ive read on here it would take a little more than that to make 500rwhp on a stock cubed ls1.
Lol damn them dynos. He should have a nice 11s sec car for sure, hopefully he finishes building the car the right way or he will be going through the same **** as me.
OP let us know what you decide and take pics of the build. Also make a new thread for the build.
So yea If you are talking about 5k for everything needed to hit 450whp reliably I think you are about right on.
Oh yea ARP stuff is pricey. I am currently purchasing all my parts for a H/C/I install over the winter. Have everything but head gaskets, bolts, and lifters. Still deciding on these parts.
OP.....will PM you back shortly
-Tony
You can hit, and exceed 450, for less than 5k. I've done it.
Tony helped me a bit, as this was with a set of AFR 205's. The newer ones (210, 215) are even better though...
450 with an auto and any kind of strong rearend is hardly easy at any price. We're all talking SAE whp, right? Hell, I've been gone a year. Did we switch to something that I don't know about? You guys know not to drink methanol, right?
