Need advice for ls1 h/c/i
Next step is tranny upgrade with at least a 3600 stall and a strange s60.
After that I'm ready for heads, cam, and intake. I've seen so many setups and brands and am looking for suggestions and experience with similar setups.
The car is not a daily driver.
Basically everything needs to line up. Starting power needs to be around 3600 rpms bc thats what kinda stall you have. Also make sure you get a bigger trans cooler from B&M.
My engine took a **** on me, failed the leak down test. However I've asked and asked many of questions. I also started with a 3600 stall so i built my car around that to line everything up correctly.
Hope this helps, others will chime in.
For Heads: AI 243 or TEA 243 are good options for stock casting. AFR 210 , TFS 215, PRC 215 would be good aftermarket options.
Cam: something around a 228/232 112 with lift around .590-.600 would be good. Go with a less aggressive lobe.
Valvetrain: keep it light! Read the sticky!!
Intake: LS6 works well but a Fast will net a decent gain.
It just works tighter and peppier without much slippage.
Then you are ready for heads and cam.
In the mean time you'll be kicking some buts without much suspicion by the victims.
4k - 440-460whp (Stage 2 243's, 228/232 cam, Fast 92/92)
5k - 480-500whp (Mamofied AFR 205's, 234/242 cam, Ported Fast 92/92)
7500 can get you a fully forged LS1 or LQ4. If you go LQ4 510-530whp should be obtainable on that coin.
all reliable setups done right...choose your goal and go from there.
There are many options for heads. You can go AFR, Trickflow, PRC heads. Othet great heads that people sleep on are WCCH, Livernois, TEA.
As far as cam goes... will you be daily driving your car? Or is this gonna be a straight up drag car? I think something like a TSP Torquer 2 232/234 would be a good size to run.
Built transmission from a Good shop
Yank 4000 stall PT series
Transmission cooler
Bigger transmission pan
Strange s60 with 390 gear
lower control arms- you already got
pan hard bar- you already got
adjustable torque arm
Find some 243s or 799s Have them sent to a Good shop for porting and Valve job
All new gaskets
A nice cam kit with all accessories Springs locks retainers etc
Push rods
New lifters
New oil pump
ls6 timing chain
Fast 90 or 102 intake and throttle body
Are you doing the work your self or having a shop install everything ?
