ported 241s or 243s?
I am just providing my insight based on personal experience.
Ironically, the next time I order new GM parts I will do so from Summit (who will price match SDPC) and they will have the parts drop shipped in from SDPC (confirmed with an LS6 valley cover) anyway - but at least Summit's customer service is sound. I doubt I will ever deal directly with SDPC again for so many reasons.
Our heads are very well known to be one of the best you can get for the money, and for good reason. We deal parts from the best manufacturers in the LS world and we also deal proven budget conscious parts and both equally receive some of the best customer service you'll find in the industry. We try to always go the extra mile to get the customer the best products at the best prices and the service every customer deserves and we will continue to do so.
Again, I'm sorry that your particular situation was not ideal. We would like all transactions to go smoothly from start to finish and we apologize dearly that we could not meet your needs. We went above and beyond to try to make the situation right in your eyes, including a 100% refund when it came to light that we could not properly satisfy you.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
If those ported 243s from SDPC are going to be $1100 for two assembled heads, I would go that route. You'll spend a grand on having your 241s ported easily.
CNC is what I do and you would be amazed how important workmanship is. Even same machine, same material same program.
One thing that seems to come up is that they have really good low-mid lift numbers but several flow tests I found show close to .600 they go turbulent which would make them a great head for lower lift cams but modern high lift grinds might suffer some.
Honestly, if I could find some solid third party testing done recently (it seems these heads might have had production changes over the years) I would be strongly considering ordering a pair next month since I was looking to spend several hundred bucks freshening up my hand ported 799s with more port work...if I could instead sell them and put that money towards the SDPC heads I would only be out a little more for potentially better heads.
How we keep them priced so low is a combination of factors on the business end of things. Also keep in mind when supply makes it possible we offer two variations of our ported heads. We offer a less expensive program using quality refurbished heads from GM, as well as a program using new heads from GM that do cost a bit more. Both are priced quite competitively in the market. Our website always specifies if the heads are refurbished.
All recent runs of heads have been on 799 castings rather than 243 castings.
I ran these heads on my C5. 346ci, 10.9 compression, 238/247 cam, and it made 471rwhp through 4.11s on our dynojet. It had 1 3/4 Kooks, and a ported FAST 90mm intake.
I have them on my Trailblazer SS as well but it has not been dyno'd.
These are for the heads we keep in stock. They have stock size valves in them and they are 64cc chambers.
• Lift Intake Flow Exhaust Flow
• .200" 147 cfm 115 cfm
• .300" 204 cfm 148 cfm
• .400" 251 cfm 189 cfm
• .500" 289 cfm 200 cfm
• .600" 307 cfm 220 cfm
For the record, seems the OP fell off planet earth.....
