Thoroughly check your whole motor...
This is why you thoroughly check your junkyard motor, even after a hot tank and rebuild.
Paraffin wax? Dried up stop-leak? Idk, but there was about 6 inches of this stuff right behind the front oil galley freeze plug blocking all oil flow back to the filter. Had to dig/drill it all out. Found my oil pressure issue.
That's MISTER MODERATOR
YES, those are oil passages.
I'm thinking that the engine saw a lot of Lucas synthetic oil stabilizer.
http://lucasoil.com/products/engine-...oil-stabilizer
Take a small flat bladed screwdriver and tap on the bottom of the freeze plug until it rotates towards you in the bore. Then I used larger flat screwdrivers and slowly pried it out of the bore.
I tapped on the recessed part of the plug, not the edge that pushes against the bore.
I had pretty good luck in keeping it in original form, so I actually just tapped it back in once I was done.
