PTV clearance?
Old Nov 16, 2014 | 09:40 PM
Kyle11784's Avatar
Default PTV clearance?
I picked up a set of heads milled .036 and think I'm going to have an issue with my ptv clearance. Am I able to run a thicker gasket in order to stop that problem? I won't mind if my compression remains stock. Just trying to save my engine before I go ahead and continue this build.
Old Nov 17, 2014 | 12:19 PM
01ssreda4's Avatar
What's your PTV with a stock gasket? Yes there are thicker gaskets. They are pricey though.
Old Nov 18, 2014 | 08:03 AM
laurentj23's Avatar
Do you know where I can get a used solid roller lifter?
Old Nov 18, 2014 | 09:17 AM
M.BOZZ's Avatar
Default lifter
I have 15 solid lifters left, I can give you one, pm me
Old Nov 18, 2014 | 11:36 AM
Aston Tibs's Avatar
You can disassemble a hydaraulic lifter and use spacers in place of the spring and make it solid. That's what I did.
Old Nov 18, 2014 | 11:44 AM
01ssreda4's Avatar
Use a comp checker spring. It will hold the valve up without collapsing the lifter plunger.
Old Nov 18, 2014 | 02:16 PM
laurentj23's Avatar
I was contemplating to do that but I don't have any spare lifters and I'm not trying my bt lifters apart
