Cam?
Old Nov 30, 2014 | 06:42 PM
Dragway's Avatar
Default Cam?
Building a lq4 with 243 heads 800 holley carb going in a grand national 200r4 with 3000 stall convertor 342 gears . I was leaning towards the tsp 224r 581/581 112 lsa any thought on cam ?
Old Nov 30, 2014 | 07:19 PM
JoeNova's Avatar
Restricted User
Without knowing what you want, nobody can answer this.
What do you want for power, idle quality, whats the purpose of the car, how early/late do you want the power to peak.. etc.
At the minimum I'd go with the TSP 228r in a 6.0. Jegs sells a 228/230 thats about a hundred bucks cheaper than most other cams and behaves very well in a 5.7, and should behave even better in a 6.0.
Old Nov 30, 2014 | 08:30 PM
Dragway's Avatar
Looking to make around 450ish rear wheel street and strip use would like to run low 12s mid 11s
Old Nov 30, 2014 | 09:11 PM
JoeNova's Avatar
Restricted User
You're going to need something bigger than the 224r for 450 to the wheels. The tsp 224 is a very mild cam for a 6.0.
Old Nov 30, 2014 | 09:19 PM
HCI2000SS's Avatar
I'm running a cam very similar to the MS3, and on my 6.0 it's none to big IMO. I'm with these guys on going a little bigger here
Old Dec 1, 2014 | 02:53 PM
thunderstruck507's Avatar
Order a cam made for a carbed application.
