LQ9 - Cam Suggestions??
My Set up:
2001 Camaro Z28
Stock LQ9
Stock 317 heads
Stock 4L60E
Stock 10-bolt
Full exhaust
SLP intake
Tuned
Goals:
400-450 HP at the wheels
Keep Stock heads
Prefer great low-mid end power and mild top end
Prefer something throaty as well
MPG is not an issue
Stay NA
I will upgrade the trans with matching stall as well as the rear end later on after the cam swap as I don't plan on beating on the car too much. Might also get the heads PnP'd if that will help some. I'm more interested in current off the shelf cams that would fit my needs before I start calling shops for a custom grind.
Any advice is appreciated!
My Set up:
2001 Camaro Z28
Stock LQ9
Stock 317 heads
Stock 4L60E
Stock 10-bolt
Full exhaust
SLP intake
Tuned
Goals:
Keep Stock heads
MPG is not an issue
Stay NA
232 232 .595" .595" 114LSA
we have the other parts you will require for a clean install as well.
spring lock retainer seal i.d. locator package
pushrods
lifters
timing set
bolts
oil pump
Keep in mind with needing a spring kit anyhow you are only a small amount of $ away from a set of ported heads. It would be a shame to do all of the work and not get as much bang for the buck as you can.
briantooleyracing.com
When you see BTR this and BTR that all over this forum, that's referring to him.
He has some good off the shelf cams that work well, but he'll have a cam ground for you if you want.
Also,Livernois has great kits to knock it all out in one shot.
I did mention I'd get the 317 heads ported/polished if need be if that will give me some additional numbers on the overall set up. I'm still in the research phase though.
thx
My Set up:
2001 Camaro Z28
Stock LQ9
Stock 317 heads
Stock 4L60E
Stock 10-bolt
Full exhaust
SLP intake
Tuned
Goals:
Keep Stock heads
MPG is not an issue
Stay NA
Our Stage 3 LS2 cam will have great power and a noticeable idle:
http://store.cammotion.com/60-ls2-34...-compression-3
And, our Titan V camshaft will deliver slightly more power and have more of a hotrod lope at idle:
http://store.cammotion.com/the-titan5
When you decide to upgrade your gears and torque converter, these cams will love a 3.73-4.10 gear and a torque converter between 3000-4000 RPM depending on your preference and driving style.
When you are ready to step up, give us a call and we will help you get all of the right parts to complete the swap.
