tv2 vs SSHT
Old Dec 7, 2014 | 04:06 PM
TXZ28LS1's Avatar
Torquer 2 would be my choice.
Imo, its the perfect size for a dd and all around. Op already said he doesnt wanna wish he could have gone slightly bigger. That would be the biggest i would run even though i run the TSP 233/239..lol
Old Dec 7, 2014 | 08:07 PM
Sladester2's Avatar
Thanks still mostly thinking about the TV2, I feel like there is no point in going smaller in a m6, I never race from 2k rpms anyway so I dont see where a smaller cam would outshine a bigger one
Old Dec 7, 2014 | 11:23 PM
whatsa347's Avatar
Why not the f13?
Old Dec 7, 2014 | 11:53 PM
Sladester2's Avatar
230/232? Hmm that seems like another viable option for me. Its right in between the 2
Old Dec 8, 2014 | 12:03 AM
Sladester2's Avatar
I just dont understand why people say smaller cams are better for the 1/8th mile? As long as you don't go below your cam's power curve it should be fine right? I mean if I don't go below 3500 in a 232/232 cam and a 224/224, the larger should give better results normally correct?
Old Dec 8, 2014 | 04:52 AM
HCI2000SS's Avatar
Yes this is correct assuming the car is setup right to take advantage of the larger cam
Old Dec 8, 2014 | 10:08 AM
sokr915's Avatar
SSHT here as well and love it.
Old Dec 8, 2014 | 11:35 PM
99Bluz28's Avatar
I have a ls1 Trans Am.
My bad!
Easy solution right here an you have the exact same cam; plus it's only $350!
http://www.texas-speed.com/p-161-com...-camshaft.aspx
That TICK cam I referred to uses LSL lobes on the regular version, and LXL lobes on the mild version. Pick you lobes (LSL, LXL, or a combination of the two) and then put in the 111 LSA and the 109 ICL (+2). My suggestion would be to go with the 231 LSL intake lobes and the 234 LXL exhaust lobes. This would cut down the total lift, and have a quieter valvetrain.
