Bad oil pressure sending unit?help
Bad oil pressure sensor?: http://youtu.be/sul9u0OD1cE
needle also seems to be moving around on idle
My 95 cluster gauge will have a delay in it. But my SpeedHut gauge reacts fast.
That doesn't look terrible. If anything the gauge looks "sensitive" as it pulses with idle lopes. OR the needle is loose and bounces around from the idle car movement. But 20+psi at idle is fine. Anything I came across says 10psi per 1000rpm is good rule of thumb.
My oil pressure went up 15 psi just by unplugging the sensor and plugging it back in........................................
