Engine Build - Going Turblowed
Excuse the YOLO! as I posted the picture on facebook earlier.
Killing me seeing all these parts chilling on the table still.. Just waiting for the block to come back so we can start fitting everything..
My engine guy sent me a picture of it last night. So far everything went in without a hitch. Going to be looking at either buying the cam or intake today.
One of our local LS1 Swapped Fox's that was tuned and worked on by the guy building my engine. Needless to say I think I'm in good hands when it comes to everything else.
- Camshaft (Custom from LJMS) - $400
- Injectors 80# - $250
- Intake (Stock LS3 as per Engine Builder) - $200
- Lifters (OEM as per Engine Builder) - $100
- Fuel Pressure Regulator - $142
- Fuel Pumps (Racetronix 680LPH Kit) - $256
- Fuel Line - $60
- Oil Pump - $150
- Boost Gauge - $60
- Wideband - $150
- Fuel Pressure Gauge - $80
- Oil Pressure Gauge - $70
- Head Gaskets - $100
- Misc Gaskets - $100
- Front LS2 Cover - $50
- LS2 Valley Cover - $100
- Water Pump - $120
Not to mention buying a rear end and having the 80e beefed up.
After she's up and running for a while I'll make the plunge over to an s480 or similar.
Curious to see how the CX Kit will work for me as well. When I make the switch to the S480 I'm just going to have someone weld a new flange on to it instead of redoing all the piping.
As for the parts, PM me and let's talks about it!
80# Injectors
Racetronix 680LPH Kit with necessary fittings
Innovate Wideband
Boost Gauge
Gauge Pod
Custom Spec'd cam from LJMS
OEM High Volume Oil Pump
IWIS Timing Chain
Lifters with Trays
All thats really left is misc gaskets and water pump.
80# Injectors
Innovate Wideband
Boost Gauge
Gauge Pod
IWIS Timing Chain
Lifters with Trays
