oil pum 6.2
Old Dec 15, 2014 | 09:54 AM
tim wellington's Avatar
Default oil pum 6.2
have a 6.2 oil pump i need to install in 2007 gmc denali . ?? i see it has access door in the bottom of oil pan .is this so you can get to oil pick up tube bolts bolt main caps .i know tube has to come down about an inch so oil pump will pull straight off. this is my first oil install while motor is vehicle . usally have engine out.
