Roller rocker recommendation...
Old Dec 11, 2014 | 01:06 PM
bluey2kz28's Avatar
Default Roller rocker recommendation...
Can anyone recommend a 1.7:1 roller rocker that they have had good results with. Also, could you warn me on what to stay away from because of your own personal experience.
Thanks
Old Dec 11, 2014 | 01:24 PM
96capricemgr's Avatar
Are you aware 1.7 is stock and aftermarket roller rockers are expensive and harder to control valvetrain mass. The vast majority of setups are better served with the "trunnion upgrade" putting aftermarket bearings in stock rockers.
Old Dec 11, 2014 | 01:32 PM
G35LS1's Avatar
COMP Cams GM LS Series Retrofit Trunnion Kits is your best bet.
Old Dec 11, 2014 | 04:39 PM
vettenuts's Avatar
I have had very good success with Yella Terra rockers. I run them with bronze guides in the heads to keep side wear down because the stock rockers don't provide a very good wipe pattern for the softer bronze guides.
Old Dec 11, 2014 | 05:02 PM
Hi-Po's Avatar
Stock rockers with trunnion upgrade.
Old Dec 11, 2014 | 07:18 PM
Russ K's Avatar
I've had Yella Terra Ultralite rockers since February 2009 when I installed TFS 215 heads. The TFS springs have ~450 lbs open pressure, and never had a failure. But I always use Royal Purple 10W40 HPS or Mobile 1 15W50 oil. In spring 2013, I installed an EPS/Cam Motion cam and BTR Platinum valve springs with ~400 lbs open pressure as I discovered that the Yella Terra Ultralite rockers might not like 450 lbs open pressure springs.
My cam specs are 234/242/.600/.615/117+2, and it pulls hard to 7000 rpm.
And I'm sure I'll never have a rocker failure with the lower open & seat pressure of the BTR Platinum valve springs.
Russ Kemp
Old Dec 11, 2014 | 07:35 PM
glen's Avatar
http://www.prwonlinestore.com/stainl...34611-1-1.aspx
Use them all the time, and, they are adjustable like the Gen 1 engine
Old Dec 11, 2014 | 08:05 PM
OP understand the comments about roller rockers and less side load are specifically as it relates to aftermarket heads with bronze guides, it is a non-issue with GM heads and their powdered metal guides.
Also remember a lot of folks who have wasted good money on "upgrades" that aren't often like to tell others how great the part is because it is easier than admitting the mistake they made.
With the LS engines the ratio is 1.7 stock and the fulcrum already roller, this isn't a gen 1 with 1.5 and a ball fulcrum where a rocker upgrade with higher ratio is a common and good proven mod.
On the LS side of things you will even find vendors telling you a $100 trunnions upgrade is better money spent than $800 roller rockers that make the valves harder to control due to weight. They have their place, but in relatively few builds.
Old Dec 13, 2014 | 05:03 AM
Robert Cantu's Avatar
Well just installed some new Scorpion race roller rockers 1.7 ratio well see how it goes BTR platinum dual 660 springs titanium retainers LS6 243's with light weight valves.
Old Dec 13, 2014 | 05:43 AM
redtan's Avatar
The vast majority of setups are better served with the "reunion upgrade" putting aftermarket bearings in stock rockers.
What is the "reunion upgrade"? Do the stock rockers hold a party 5, 10, 20 years after graduation?
Old Dec 13, 2014 | 06:38 AM
redbird555's Avatar
I lol'd ^
Old Dec 13, 2014 | 06:43 AM
Friggin spellcheck on the phone...........
Old Dec 13, 2014 | 07:01 AM
T/A2000's Avatar
Yella Terra or if you have the $ to burn jesel shaft mounts, are the only real options for a roller rocker on a ls engine imo.
Old Dec 13, 2014 | 07:40 AM
01ssreda4's Avatar
Originally Posted by Robert Cantu
Well just installed some new Scorpion race roller rockers well see how it goes.
Yuck Proven track record of failures.
Old Dec 13, 2014 | 10:26 AM
kinglt-1's Avatar
Stock or Shaft mounts seem to be the best options. Aftermarket pedestal mount RR's are heavy at the roller and harder to control.
Old Dec 13, 2014 | 11:19 AM
Hi-Po's Avatar
Probably the worst choice you could have made.
Old Dec 13, 2014 | 11:26 AM
T/A2000's Avatar
^^^^^ Exactly
Old Dec 13, 2014 | 12:11 PM
hiltsy855's Avatar
PRW roller rockers? I bought a set of their stainless rockers a while back. They are very heavy and I wasn't too impressed with the quality. Some of the roller tips weren't square with the pivot. I contacted PRW and they sent me 3 new ones but they weren't much better so I ended up returning the set.
Old Dec 13, 2014 | 12:43 PM
Fry_'s Avatar
You gotta love when someone comes in and ask for advice only to completely ignore all of it.
Old Dec 13, 2014 | 02:20 PM
KCS's Avatar
KCS
Moderator
It's funny how these "hard to control" aftermarket rockers keep ending up on these 500whp LS1's...
