Gasket help
Old Dec 20, 2014 | 01:45 PM
Lethalwx69's Avatar
Default Gasket help
I bought a Felpro gasket kit for my Lq4 built, and I'm confused as to where these gaskets go. This built is for a 2002 z28 with ls1 crank, heads, intake...etc. 2, 3, and 4 I'm pretty sure those are different size rings for the oil pickup tube. Help would be much appreciated. During my tear down I do not remember any of these gaskets.
Old Dec 20, 2014 | 02:07 PM
Burken01's Avatar
What a puzzle, (2,3,4) oil pump o rings
(5,11,12,13,14) all look like the oil cooler plate gasket that goes above the oil filter..
(7,9) looks like the top and bottom injector o-rings
(1) I have never seen that
Old Dec 24, 2014 | 12:34 AM
joecar's Avatar
That kit looks wrong.
Old Dec 24, 2014 | 06:36 AM
RezinTexas's Avatar
I'm guessing these are the left over seals from your kit? You have already used the remaining seals in the correct places?
2,3,4 - oil pump pickup tube.
6 - oil level sensor.
11,12 - oil cooler lines at oil pan.
5 - oil cooler lines block-off at oil pan.
9 - dipstick tube?
I don't know about the rest.
Old Dec 24, 2014 | 06:54 AM
LS1MCSS's Avatar
1 is the water pump rear cover gasket. You can trash it.
Old Dec 25, 2014 | 04:24 PM
joecar's Avatar
#1 is not an LSx water pump rear gasket (it might be a 2.8/3.1/3.4 WP gasket).
#10 might be an LSx WP rear gasket.
The long shaped ones are not correct for LSx oil cooler plate.
#9 might be fuel line o-ring.
The kit looks totally wrong for LSx.
OP, show us the part # of the kit.
