Lq4
Old Jan 2, 2015 | 04:15 PM
Moogambo's Avatar
Default Lq4
Hi noob here, Awsome site, I am learning a lot. I have a 67 chevy II with a LT1 in it and have a chance to pick up a 2003 6.0 out of a truck with about 7000 miles on it. What would be top dollar everyone would pay for that motor. Has the ecm and harness, wires going towards the trans were cut and is missing starter. Everything else is there.
Thanks
Old Jan 3, 2015 | 10:24 AM
Moogambo's Avatar
I can pick it up for 1800.00
Old Jan 3, 2015 | 11:54 AM
iliveonnitro's Avatar
I bought a 2000 LQ4 for $1000 (with starter motor, without A/C compressor), though it had the iron heads and longer crank. I got a pretty good deal on it, but it had 120k miles on it.
For 7k miles on a 2003 including everything but the start motor, $1800 sounds more than fair.
Old Jan 3, 2015 | 12:20 PM
96capricemgr's Avatar
If 7000 miles, not 70,000 then it might be a good deal if it was well kept all these years. If it sat outside in a smashed up truck with the intake tract wide open many be no depending on your climate. Location also matters a lot in value.
Old Jan 3, 2015 | 12:46 PM
Moogambo's Avatar
I,m in Illinois and it came from a rear end wreck, it has been covered in a garage for ten years.
Old Jan 3, 2015 | 09:25 PM
jerr6's Avatar
i think its pretty good deal. only 7k miles is good. im in illinois too and just picked up a 06 74k mile lq4 for $1600 from salvage yard.
Old Jan 5, 2015 | 08:05 AM
gagliano7's Avatar
Make sure it turns over freely. That is a long time for a motor to sit without it being rotated. Make sure you spray something through the spark plug holes before you rotate it for lubrication.
