cam selection help
Old Jan 15, 2015 | 01:43 PM
gmoutdoorsman's Avatar
Originally Posted by gtotoocool1
whichever grind you go with,make sure you take the time to set up the valvetrain properly and degree the cam.well worth the time and money..
Multiple local LS guys (with more experience than I) claim I dont need to use a degree wheel. Just put it in "straight up" I was a lil concerned about it. Got some more experienced guys that are gonna help me install the cam
Old Jan 15, 2015 | 04:17 PM
Darth_V8r's Avatar
Moderator
Originally Posted by 01ssreda4
Rear gear, long tubes? Plan/goals for the car?
I really like the Titan4 from Cam Motion. Check it out.
http://store.cammotion.com/the-titan4
(All Titan Series cams are available in 3 Bolt and VVT.)
Grind# XA227/360-XA232/350-13+4
Duration at .050 - 227/232
Lift with 1.7 - .612/.595
Lobe separation 113
Intake center line 109
Usable RPM Range 2000-6400
That is extremely similar to a custom cam grind that Martin (Tick) made for me. Saving up to buy it. Highly recommend you ask Martin his opinion as well.
Old Jan 15, 2015 | 08:03 PM
Tick performance? And talk to martin? I guess let him knowthe details of my build/setup and my goals?
Old Jan 15, 2015 | 09:05 PM
01ssreda4's Avatar
Regardless, let the vendor know you'd like cam motion to grind it if you decide to go with a custom cam.
Old Jan 16, 2015 | 04:18 PM
Ok thanks you
Old Jan 18, 2015 | 09:27 AM
gtotoocool1's Avatar
I disagree..due to tolerance stacking,your advertised ICL could be way off,whether you put it in straight up or not..degreeing a cam simply tells you what the ICL of the cam is in the motor,it doesn't change anything.
as an example,the last cam I installed was supposed to have an ICL of 109.it was actually at 111..
just my .02,it's your car bro.
Old Jan 18, 2015 | 10:03 AM
TXZ28LS1's Avatar
OP,
Since this is a daily driver, i wouldnt go any smaller than a 228 cam from TSP. If you wanted a bit more, than the Torquer 2 would be the biggest cam i would daily drive. Just do a search. You will see countless threads and vids of those 2 cams.
