Head Advice: Noob Seeking Torque Monster
https://ls1tech.com/forums/dynamomet...o-results.html
So i was able to pick up a set of 243 heads fresh from a machine shop where they received a 5 angle valve job, .005 removed for cleaning, and had the chambers smoothed.
My question is should I have them milled more or just run a thinner Cometic head to bump up the compression? If a thinner gasket, what thickness would you guys recommend?
Note: I will be running 93 octane.
Thanks so much in advance guys.
