5.3 build. 4x4 rcsb.
Reuse crank and rods
New flat top pistons
243 heads
Tsp220r
Ls7 lifters
High volume oil pump
Ls2 timing chain
Reuse rockers with comp reunions
ARP head studs, rod bolts
Tsp hardened push rods
Double valve springs with titanium retainers
Lt headers
Tsp ory
Tsp by yank 3000 stall with lock up
Transgo hd2 shift kit
Vette servo
Questions I have are what cr would I be looking at with heads and flat tops? Should I port and polish the heads possibly mill them down? Oversize valves? Floating or pressed wrist pins. What are pros and con's of each? What head gaskets should I run? I've heard of people using ls6 for there lower crushed thickness. Any other upgrades I should consider? Tuning will be done by Justune Here in kc. For those of you who don't know who that is he is the owner of "reddragon" I would love to hit 400rwhp but I think that's a little out of reach n/a and no spray. Thanks everyone!!
Porting a set of either would be good.
I wouldn't bother with larger valves, several vendors get great results with the 243/799s with stock valves even with the larger bore on the 5.7l engines.
