sleeve ls1 block?
Ive seen that mid sleeves are a option for the aluminum ls1 that i have now. Has anyone used these before that have first hand experience? It shows that there is a 4.200 max bore for the sleeves and that 401 CI is achievable with the stock crank. Is it possible to get even more displacement with an aftermarket crank? I want 427CI+ but not interested in the hefty ls7 block price. Thanks guys.
However, you can go 454 with a resleeve vs ~440 on the LS7. The sleeves allow a 4.200" bore and a 4.155" crank. The bores are longer than the stock block's sleeves and allow for a much longer stroke without issue.
