ls6 Springs and these Lobes???
Lunati 20540713 (Formerly Part Number 60513) GM V8 LS Gen III/IV, 3-Bolt Hydraulic Roller Voodoo 3-Bolt Core Camshaft RPM Range 1800 - 6400 Lift .549"/.549" Dur.@.050 217/223
i think lunati these lunati springs are speced for the cam.
Type: .600" Lift Ovate Beehive Valve Spring
O.D. Big End: 1.290"
I.D. Big End: 0.885"
O.D. Small End: 1.055"
I.D. Small End: 0.650"
Coil Bind: 1.140"
Seat Load: 130@1.800"
Open Load: 318@1.200"
Rate (lbs/in): 313
Quantity: 16
Part Number: 74818-16
Previous Part Number: 74818LUN
thanks
You probably aren't going to be using it's lightweight valves and you will be needing to spin more rpm, two BIG disqualifiers even before we consider an aftermarket lobe likely being more aggressive a ramp than a production OEM cam.
If you want a cam to use stock springs stick to a stock cam AND limit valve weight to what was used with that combination of cam and spring.
For example LS6 springs will NOT work right with an LS6 cam and stock LS1 valves because the LS1 valves are solid and heavier.
***Not true, they work fine. I've had two with no problems, winding up to 7k rpm.
A valve train is a system of engineered parts and needs to be matched correctly or the disaster can be catastrophic.
GM didn't do hollow/sodium filled valves because they wanted to spend more money.
Again talk to a vendor they can pick a mellow lobe and spring to handle it long term.
http://www.hotrod.com/how-to/engine/...st-comparison/
LS6/2 cam floated at 6200
