6.0 cam change. Should I chnge springs???
I am looking at a cam for my LQ9. It is a Lunati 212/218 113/109 .531/.531
So the question is: Can I get away with the stock springs that have 97K on them?
Thanks!
Thanks!
Last edited by 52F1; 01-25-2015 at 10:22 PM. Reason: Was off a number on the cam spec
I would do the LS3 springs. They only 60 bucks new and can take 560 lift new.
NO, if it's the VooDoo series ! Since those lobes have a aggressive lobes (ramp rate's 50) which need noticeably more spring rate to control. I also wouldn't use the LS3 springs. I'd get a set of PAC-1218 and shim them to within about .05" of coil bind for long life and good control of that VooDoo cam.
http://www.ws6project.com/user_stor/...valve-springs/
You'll likely be fine without shimming them to within .05" of coil bind, but shimming will still be better.
