LQ9 compression ?
Old Jan 29, 2015 | 07:53 PM
bcearley's Avatar
Default LQ9 compression ?
i found this for the LQ4
looking for something similar for the LQ9
the plan is 69 cc combustion chamber 243 on LQ9
also need some cam suggestions this is going in a truck
have intensions of adding a little spray latter also
Old Jan 29, 2015 | 08:12 PM
A.R. Shale Targa's Avatar
A Chevy Luv truck or a quad axle dump truck ???
trans
converter
gears
weight
tires
intended usage
how much spray
what intake
headers/exhaust
stock 243s or ported
hand or CNC
what head gaskets
Help us help you
Old Jan 29, 2015 | 08:22 PM
bcearley's Avatar
A Chevy Luv truck or a quad axle dump truck ??? 2006 crew cab 1500 Z71
trans 4L80
converter Stock
gears 3.43
weight ?
tires oversized mud tires
intended usage towing mostly
how much spray ?
what intake stock truck intake
headers/exhaust not sure yet
stock 243s or ported ported
hand or CNC CNC
what head gaskets stock LQ9 gaskets
Help us help you
Old Jan 29, 2015 | 08:23 PM
askkmb's Avatar
Add 0.70:1 compression to the table you have and it applies to the lq9. Cant confirm but you should have 10.96:1 compression using stock lq9 bottom end with stock head gaskets and stock 243s.
Old Jan 29, 2015 | 09:32 PM
so quite heavy vehicle....6000lbs or so/ heavier when towing
medium gears made even worse with bigger taller tires
no stall converter
stock exhaust
about the only thing helping you is some decent heads and bumped up comp
I'd call Geoff at EPS and plan for a small fuel efficient torque cam in the 212-218 @ .050 range with 570"-580" beehive friendly lift
