G5X3 -vs- F13
the very beginning is partial throttle350rwtq at 3000 aint too shabby to be going through a 12 bolt on 18 inch wheels air filter in place
yours on 29 degrees of timing, low altitudes, 93 octane etc....
mine on 23-24 degres, high DA, 91 octane with MTBE etc... Your numbers will be SIGNIFICANTLY lower here. In Texas Lou consistently makes 440-450 rwhp in the Z06 cars with stock heads... but of course thats with 94 octane and real timing. Compare two like climates and I Think the G5X3s will come out on top. Im not ragging on the F13, I just feel Lous cam is superior here for my personal needs (And that of every customer of mine ive installed one in)
I am with Mike on this one personally since I own the cam and it works for me, but the F13 seems like a bad *** cam too, never seen on done here in AZ though. There is no way to compare these really, both make good power, but it's hard to get accurate results on a stupid dyno. You can have some jerk off mess with the dyno and you can make a million HP, but what counts is at the track, supposedly so far the fastest LS1 N/A stock cubes, etc etc, runs a G5X2 cam, what else can do you need. I am sure there are faster cars, but this cam performs. My car is not the best dyno car, and I wish it were so I can brag my *** off, but I know it will perform on the street/strip and that's what counts. I have seen a car that has 650 RWHP run a 13 at the track, driver sucks ***, but he has 650 RWHP
The only way to see which cam is really better or makes more power is to dyno one, swap it out on the same car with the other cam, the same day, as fast as you can, then redyno it. Not gonna happen, so I guess be happy and choose wisely
TIA,
Justin
TIA,
Justin
TIA,
Justin
Wish I could say that was now, but I have many little things to attend to first.
Thanks again,
Justin
