Grinding timing cover?
Old Jan 30, 2015 | 03:19 PM
Azuber01's Avatar
Default Grinding timing cover?
I have a 99 lm7 I put a double roller on it. Already ground down some but it looks like the only place it doesn't fit is where the balancer gasket goes. Can I grind that circle down or no? Thanks
Old Jan 31, 2015 | 09:10 AM
Mercier's Avatar
The inside of the hole where the seal /seals/ would be a bad spot for grinding. You would produce an oil leak. As long as you don't grind any place that directly touches the seal you should be ok. Take a pic so we know exactly what you are suggesting.
Old Jan 31, 2015 | 03:00 PM
Azuber01's Avatar
I figured it out. It was just a pita...
