Cam and head selection
Old Jan 24, 2015 | 09:43 PM
HOTSIX's Avatar
Default Cam and head selection
I'm building a 6.0L LQ4 to go in a GN.
I am trying to pick heads and a cam - plus I have read the stickys!
My engine builder has a set of aluminium 862's that he rebuilt and added LS6 springs to for me...issue is I gave him the green light on them before I had honestly made up my mind on them. I believe these heads came on the 5.3's or 6.0 engines.
I am really kinda stuck with the 862's as he has done the work...so question is do I use them ?
I am aiming for a car with street manners - hoping for 450-500 HP. I am looking at the L92's with a GMPP HotCam. After some reading it looks like GMHTP has done this as have some other magazines and it proved great numbers. Should have done more research before I pulled the trigger!
If I stick with the 862's and HotCam how much HP/TQ will I be sacrificing? The 862's have much smaller valves and lower CFM of course....
Old Jan 25, 2015 | 02:59 AM
Tuskyz28's Avatar
LQ4 means you need some compression If you going all motor. I would skip right past the 862 heads and go right to the L92/LS3 head for your power goals. Maybe if your budget I would get the heads milled to add a tad bit more compression. You mention running a gmpp cam. I would skip over a gmpp cam for either a tooley cam/tick cam.
With 225 intake duration that combo made 470rwhp.
I'm not go say the 862 heads can't make the power but you'll need a bigger cam which means less great street manners.....
Old Jan 25, 2015 | 06:47 AM
96capricemgr's Avatar
Those hp goals flywheel or rear wheel?
If flywheel that is an 11second car that could need a rollbar if you make it work right.
If rwhp then it is 10s.
The rectangle port heads on a 4.00 bore are favored only when blindly looking at peak numbers and ignoring average output.
The 862s ported by some random local guy could be anything between amazing and paperweights and literally anything in between.
Old Jan 25, 2015 | 08:29 AM
A.R. Shale Targa's Avatar
Aren't the 862 chambers small...??? Like 61 cc or so ??
That would kick the 9.4compression up to around 10.85 with GM gaskets
I'd bet KCS could verify if the 5.3 seats can be machined out to 2"/1.55" valves. If not I'd still just port them and toss in one of Martin's (Tick) street heat stg.1 V2 cams and that thing will make great average torque....with the right exhaust and tune I'd bet 425 rear wheel or so.
IMO the LS3 heads belong on a larger bore/engine in order to develop faster port speed during low rpm driving.
Old Jan 25, 2015 | 08:33 AM
speedtigger's Avatar
Old School Heavy
What intake are you running? Still have the TH200 trans? What stall converter do you have? Still have the 3.42 rear gear?
Old Jan 25, 2015 | 10:57 AM
HCI2000SS's Avatar
I'm running the 5.3 heads (862 casting) on a LQ9 and with good compression it moves out really good!
Old Jan 25, 2015 | 12:05 PM
HOTSIX's Avatar
Thanks for the reply guys.
I am running the 200 trans but its built. Lots of billet internals etc. I have a 2800 lock up converter and am still running the 3.42 rear end gear. My HP goals are rear wheel but I'm not a dreamer either. I'll be using an LS1 intake for now...but will likely move up to a FAST. Don't want to limit myself by picking poor heads / cam at this point...but the car must have decent street manners and isn't a daily driver.
The motor is not together yet and I'm at the point of cam selection. Im interested in the Tick cam...having a look now.
After doing some more searching - it appears the L92 heads only really matter +5,000 rpm. I'll be more interested in low end torque at this point.
Old Jan 25, 2015 | 01:12 PM
2800 stall/3.42 and NA 450+rwhp is a a contradiction.
Old Jan 26, 2015 | 07:48 PM
HOTSIX's Avatar
How you mean a contradiction?
Not possible? What do you suggest...
Heres an old article - 6.0L LQ4 with a HotCam and LT headers - stock heads - 483 flywheel HP. Not bad.
http://www.hotrod.com/cars/project-v...4-short-block/
How much HP loss through drivetrain....a bit but still very respectable numbers at the wheels.
Old Jan 26, 2015 | 07:56 PM
That is maybe appropriate stall for a 450+rwhp turbo car but and NA one will want probably 3600-4000/ 3.73-4.10
Old Jan 26, 2015 | 09:40 PM
KCS's Avatar
KCS
Moderator
Yep, the 862 heads have big enough seats to go to 2.02"/1.60".
Even with the stock 1.89" intake valves, I'd bet they'd still make more low and mid range power than a set of L92 heads. You're talking almost an entire point of compression between the two heads.
Old Jan 26, 2015 | 10:07 PM
Old School Heavy
If it were mine and I was on a tight budget, I would go square port heads for sure. Yes, it will have lower compression and less low RPM torque, but once it gets wound up, it will run like a scalded dog. There are a couple reasons why I think it is a better situation. First, the LS3 intake is a better intake than the LS1 or LS6 intake and maybe every bit as good as a Fast cathedral port. I am betting that you can get into an LS3 intake cheaper than a FAST. Second, if it is a daily driven street car, it will likely have regular street tires on it. So why try to concentrate the power down low where it will just spin the tires anyway. I say move the powerband up where you can use it once you are rolling.
Just make sure you choose the camshaft carefully and don't overcam it.
Old Jan 27, 2015 | 09:45 AM
2800 stall 3.42s will make for race over before the rectangle ports start to work.
Old Jan 27, 2015 | 10:17 AM
Tuskyz28's Avatar
I personally think you can be successful with either head..... only with one exception... the rectangle port head camshaft is VERY VERY CRITICAL. This is why you really see the LS3 combos being a hit or a miss.
Old Jan 28, 2015 | 01:05 PM
HOTSIX's Avatar
What are your thoughts on working over the 862 heads a li?
As KCS indicated - going 2.02 / 1.60 valves....what benefits will I see here and is it worth the cash?
Keeping in mind that this is a street car that will prob never see the track and is no DD.
Old Jan 28, 2015 | 03:15 PM
KCS's Avatar
KCS
Moderator
You would probably have a hard time making over 400whp with the smaller valves. At the very least, I would have a valvejob cut for a stock 2.00" intake valve and leave the 1.55" exhaust valve alone. If you're the DIY type, you can open the throat to 90% of the valve diameter and blend it all in with a grinder/Dremel, or you can have your machinist do it.
I did something pretty similar in my Trans Am with a set of 241 heads. I used 2.02"/1.60" valves, opened the throats to 90% of the valve diameter, blended it all in up to about the valve guide, and it made over 410whp before the clutch would let to at about 5000RPM.
Old Jan 31, 2015 | 08:22 PM
JakeFusion's Avatar
Super Hulk Smash
2800 stall... I'd go with something like a 226/234 type of cam with those 5.3L heads. That combo will work well on the 6L and make a lot of usable power.
