Questions on Cam build
Old Feb 8, 2015 | 07:53 AM
A.R. Shale Targa's Avatar
Brian Tooley has a stage 2 cam that's right in the range that Jake suggested.
A new LS chain which fits your stock gears is only forty bucks and a new oil pump is in the 125-150 range. If you can afford a set of good used 243/799 castings, the upgrade would certainly help even if you cant send them out for cnc porting. A valve job, clean up surface, and dual spring kit (also from Tooley) combined with some .040" Cometic head gaskets would give 11 to one compression to help the larger cam thump with some intensity.
An LS6 intake for $350-400 would also be in that 5-8 rear wheel horsepower.
Old Feb 8, 2015 | 08:20 AM
TRD2006's Avatar
Thanks guys, that cam motion 228/232, I called about and the guy recommend the lsa114 + 4, what does that mean compared to the 111 + 4?
Old Feb 9, 2015 | 10:21 AM
JakeFusion's Avatar
Super Hulk Smash
The 111 LSA will have more overlap and overlap = power. It'll drive worse, sound better, and make more torque with all things considered. It'll also be a more "intense" torque curve... meaning the 114 will actually make power over a broader RPM range, but the 111 will bring it in more violently in the midrange. At that size, the 228/232 works well with the 111 in the 5.7L... it doesn't have excessive overlap to make it drive horrible. But it has enough to make power. I'd only do the 114 if you plan to up the compression to 11.5:1.
That's where the combo makes sense. The TFS As-Cast 220s at 63cc chambers or so with the 228/232 111+3 would be pretty satisfying in a street car.
Old Feb 9, 2015 | 12:35 PM
josh4ku's Avatar
Originally Posted by 2011grandsport
There is one item that everyone has overlooked on doing this cam swap. CAM BEARINGS!
With the amount of miles on the clock 180,000 i believe is what the OP stated, the cam bearings are going to have a lot of wear on them. If they show any of the copper looking color then they will definitley need to be replaced. Just keep this in mind when you tear into it.
I also agree with the other guys about using a less aggressive cam lobe, especially if this is a daily driver.
Every cam bearing I've ever seen habe copper showing. I've seen from 40,000 ls1 to 140,000 miles. I've always reused with no problems.
Old Feb 9, 2015 | 04:40 PM
mac62989's Avatar
114 with 11:5:1 because you have the added compression? Referring to AI HCR 241s at 11:5:1
