LS head coolent blockoff broken inside
Old Feb 5, 2015 | 10:03 PM
nastyiroc's Avatar
Default LS head coolent blockoff broken inside
On each side of these 799 heads I have there looks to be a broken nipple from the block off in each side of the head. I just had them sent out to be cnc ported and when they came back they still had these pieces in them. Is this normal or did they forget to extract them? Also how shall I go about getting them out of they are indeed stuck in there? Thanks
Old Feb 5, 2015 | 10:19 PM
WE TODD DID's Avatar
Normal. They're plugged from the factory. Put that end on the back side of the engine.
Old Feb 6, 2015 | 05:41 PM
10droped's Avatar
When I removed mine I just took a punch and hammer and drove them out from top to bottom, they came right out
Old Feb 6, 2015 | 05:54 PM
nastyiroc's Avatar
Then I put the blockoff in after I punch them out?
Thanks
Old Feb 6, 2015 | 05:56 PM
Thanks
They're already blocked off. No need to mess with them unless you want to put a crossover there.
Old Feb 6, 2015 | 06:48 PM
10droped's Avatar
My bad I thought you under stood what they were, I knocked them out to used the stock coolant tube
Old Feb 7, 2015 | 08:12 PM
Paul Bell's Avatar
That's MISTER MODERATOR
GM bolts a block over the steam ports with a nub that pokes into the hole. If that nub is broken off in the head like that and you don't fix it, the nub can come out and cause a leak.
With the head off the engine, you should be able to knock it in then shake the head until it drops out.
Old Feb 7, 2015 | 08:40 PM
redbird555's Avatar
Ya but thats not what this is lol. New casting heads have a plug pressed into them like the op's. Its not broken thats the way they come from gm I've had a few sets of heads like this. They're ready to go unless he wants to add a crossover. Gm stopped using coolant plugs like the one in the pic quite a few years ago and just did things this way
Old Feb 7, 2015 | 08:52 PM
Paul Bell's Avatar
Interesting.
Old Feb 8, 2015 | 09:09 AM
10droped's Avatar
Yup that's how mine where too, mine came off a TBSS.
Old Feb 8, 2015 | 07:53 PM
nastyiroc's Avatar
Cannot thank you guys enough!!! I tracked down a brand new pair of 799 and they were plugged so these are going to stay as is. Do appreciate all of the feedback!!
Old Feb 9, 2015 | 12:06 PM
Robert Cantu's Avatar
If these were pushed out in motor with heads on can the pins be removed out the water pump or what how? Thinking of doing this to mine when I found my heads were like this any suggestions.
Old Feb 9, 2015 | 02:42 PM
Jontall's Avatar
Can't do it with the heads on the car.
Old Feb 9, 2015 | 05:13 PM
Are you sure it's impossible? Where will the pin plugs drop to if pushed them in with heads on car I might can push it through but will I be able to get them out? Anyone have some input on this.
Old Feb 9, 2015 | 08:49 PM
nastyiroc's Avatar
Why would you want to take them out?
Old Feb 9, 2015 | 11:32 PM
Because I have a 4 corner vent kit that I bought..
